Emails stopped appearing
  • 4 replies
  • 2 views
  • Last reply by rjsmith31
Since the last Thunderbird update emails to my POP accounts have stopped but I'm still receiving emails from my IMAP account on a different server. I'm running Thunderbird 102.0.3 under Windows 10. I know there should be emails to my POP accounts as I use a front end which lists the emails. I've tried not using the front end with the same results. My emails disappear! Please help me.
Any emails should be sent to rossjsmith68@gmail.com as it is the only account that is getting through.
Since the last Thunderbird update emails to my POP accounts have stopped but I'm still receiving emails from my IMAP account on a different server. I'm running Thunderbird 102.0.3 under Windows 10. I know there should be emails to my POP accounts as I use a front end which lists the emails. I've tried not using the front end with the same results. My emails disappear! Please help me. Any emails should be sent to rossjsmith68@gmail.com as it is the only account that is getting through.
All Replies (4)
Are you receiving any error messages?
Hello David,
I'm not getting any error messages.
Thanks Ross.
Are you receiving message that there are no new messages? If not, your best bet may be to remove the account and start fresh. If it is a POP account, I suggest copying the mail folders (with Thunderbird not running) elsewhere until account reinstated.
After two days of not receiving my emails, all of a sudden they are appearing again. Despite me not changing anything! We'll see if this lasts.
Thanks for the suggestions. Ross.
